8/12/2015 8:07 PM | |
Posts: 439 Rating:
Hello, I joined a pdf to my post. (it's in french but printscreen talk for themself) It's a procedure to delete the unused licensed and keep the good one. You just have to transfer your good license to a usb stick, let the bad one on your C: drive, delete the hidden folder and bring back the good license from the usb stick to the C: drive with license manager. Then, select all the good license on the C: drive and with the right mouse button select "Check". Open TIA Portal. I hope this will help you. Best regards, Hugo AttachmentProcedure pour supprimer license defectueuse.pdf (370 Downloads) |
Last edited by: HugoDufour1 at: 8/12/2015 8:10:40 PMLast edited by: HugoDufour1 at: 8/12/2015 8:31:27 PM |
