9/5/2015 10:53 PM | |
Joined: 3/14/2008 Last visit: 10/15/2024 Posts: 2111 Rating: (942) |
I bet you have the reaback option: "OCM parameters only" selected. You need all. why are you using datablocks? Are you coming from s7 programming? I suggest you use standard pcs7 blocks for digital/analog readings and writing. also use your own (scl or some sort) blocks in cfc with block parameter attributes to communicate those to wincc |
