Industry Online Support
1/21/2008 8:02 PM | |
Posts: 133 Rating: (13) |
This error got me the first time I tried DCC (Drive Control Chart). Basically what it is saying is that if you have a connection between a DCC chart and a normal drive chart (parameter or BICO connection) you must create a parameter to define this. These parameters start in the 21500 range if you want to look them up in the expert mode when you create them. To publish the connection click on the DCB (drive Control Block)connection to open up the window and type in @*250 topublish it as the first available parameter. The manual for DCC can be found on the documetation site below. https://www.automation.siemens.com/doconweb/content.asp?item=2326&cd=sinamics_0707_e&scope=all |
