3/6/2016 2:15 PM | |
Posts: 46 Rating: (1) |
Hi all CPU417H: 6ES7 417-4HL00-0AB0 |
3/6/2016 4:42 PM | |
Joined: 1/21/2013 Last visit: 3/19/2024 Posts: 4618 Rating: (705) |
Hello counter, this is the successor, and If you read this FAQ should no problem to use H Syns submodule with this new CPU there is also this http://plc-trade.com/media/pdf/6ES7417-4HL04-0AB0-datasheet-en.pdf |
Last edited by: Ste39 at: 3/6/2016 4:45:27 PMLast edited by: Ste39 at: 3/6/2016 4:48:14 PMLast edited by: Ste39 at: 3/6/2016 4:57:25 PM |
3/6/2016 5:37 PM | |||||||||||||||||||||||||||||||||||||||||||||||||
Joined: 3/28/2015 Last visit: 5/25/2024 Posts: 721 Rating: (213) |
Hello, Perhaps the following topic might help: What should you watch out for when changing from one S7-400 CPU to another?
Eng.Mohamed Ibrahim |
3/7/2016 5:17 PM | |
Hello, Phase-out Announcement: 10/1/2012 Product Cancellation: 10/1/2013 Product Discontinuation: 9/30/2022 End of spare part delivery, end of repairs, end of customer support. Perhaps the following topics might help: 1-TIA Portal Readiness Check Tool The TIA Portal Readiness Check Tool offers an easy way to check if the hardware included in projects is supported by TIA Portal. To create new TIA Portal projects or to migrate projects from older versions you must first check that the available hardware components are supported by the current version of TIA Portal. |
3/8/2016 8:38 AM | |
Thanks But Rediness check tool doesnt show any replacement in for TIA... Any more suggestion bye |
