11/21/2016 5:00 PM | |
Posts: 15 Rating:
Hello from France, I have a Operate V4.5 +SP3. I've allready done the Systemconfiguration.ini & Slamconfig.ini (See below) I try unsuccessful to open my Runtime Wincc Advanced (TIA PORTAL) in Full Screen. Every time when its opened, I have a windows. I try to use the OEMFRAME.INI file, but I can't found the correct value for the WindwsStyle_Off parameter. Where I can found this ? Or can you help me to found the correct value ? Thanks a lot. Jean-Denis --------------------- Systemconfiguration.ini [processes] PROC600= process:=WinCCFlexOEM,cmdline:="c:\Program Files (x86)\Siemens\Automation\WinCC RT Advanced\HmiRTm.exe C:\ProgramData\Siemens\MotionControl\compat\user\pdata.fwc", oemframe:=true, deferred:=true,classname:="HmiRTm" PROC604= process:= STEP7, cmdline:="C:\Program Files (x86)\Siemens\Step7\s7bin\s7tgtopx.exe", oemframe:= true, classname:="s7tgtopx", deferred:= true [areas] AREA600= name:=AreaWinCCFLex, process:=WinCCFlexOEM AREA604= name:=MonSTEP7, process:= STEP7 Slamconfig.ini [AreaWinCCFLex] TextId = WinCC TextFile = oemtxt TextContext = contextOEM SoftkeyPosition=7 AccessLevel=7 [MonSTEP7] TextId= STEP7 TextFile = oemtxt TextContext = contextOEM SoftkeyPosition=12 AccessLevel=3 |
11/24/2016 3:33 PM | |
Joined: 4/23/2015 Last visit: 6/11/2024 Posts: 76 Rating:
Hello, Did you do what it has been described in the enclosed Manual? You have to match between the Operator Panel type and the Resolution in your Project. Best regards, KP AttachmentWinCC V13 SP1_p51p52.pdf (634 Downloads) |
11/28/2016 9:16 AM | |
Posts: 15 Rating:
Of course I did it. When I Start WinCC Flex without Operate, it's in full screen. When I start it in Operate, it's like a windows... |
12/6/2016 1:51 PM | |
Which Sinumerik Integrate Create MyHMI/WinCC version do you use in your project? Best regards, KP |
