2/17/2017 12:05 PM | |
Posts: 71 Rating:
Hi adsmdm, of course. The example image comes with Python pre-installed. node.js is also part of the image and enables you to run your JS code. Have a look at the mraa library code examples to get an idea how to access GPIOs from your Python or JS script. If you prefer to write even less code, you might want to try node-red (also pre-installed). |
