7/6/2017 9:54 AM | |
Posts: 9 Rating: (0) |
I have survilliance module mounted on gantry machine along with the IR module 611D After surveillance module 6SN1112-1AC01-0AA1 four LT module are connected. When i switch on the machine all the LT modules having -X135 LED glow except the module after this particular surveillance module and I am getting the alarm Drive bus hardware fault. I thought that the problem with surveillance module or with its -X351 equipment bus. I changed the module but no effect. No any LED is glowing in this module. Can some one suggests any remedial action. Please provide the pin details of -X351 equipment bus connector. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 7/6/2017 3:08:53 PMNew subject after splitting |
7/9/2017 5:49 AM | |
Joined: 10/17/2007 Last visit: 5/1/2024 Posts: 3980 Rating: (340) |
1st 6SN1112-1AC01-0AA1 is Monitor Module in English or UEB in German, it supply only control voltage out put from flat cable, there are some LED's on it , Green, yellow and red. 2nd You are not new member /user here, can you please post picture to support what your problem did you read the tips at the top of Drive branch and CNC branch of this forum--if you have picture, I can almost answer you what is wrong, you made delay help by yourself Sorry for my straight I don't think bus detail can help you but i post it here--German version drawing available please ask
AttachmentRIBBON_CABLE_DATA.pdf (596 Downloads) |
Last edited by: nulizhang at: 7/9/2017 6:03:07 AMdrawing source from Dave, Forum memeber , in June 2009, thanks If you like my comments please |
