8/29/2017 8:50 AM | |
Joined: 9/23/2005 Last visit: 4/26/2024 Posts: 4522 Rating: (698) |
You are using old version of 416-3. It supports only 2048 FC blocks. BTW, your CPU should have at least FW 4.0.1 if I'm not wrong... And recommended is FW 4.1.1 -> see So, if your project has more then 2048 FCs, I think you need newer CPU - they support up to 5000 FCs. But to be 100% sure please ask the Support. |
Regards, |
8/29/2017 3:32 PM | |
Joined: 1/26/2014 Last visit: 3/19/2024 Posts: 164 Rating: (0) |
Dear jacek d, Thank you for help. I think the only solution to increase FCs range, remove unuse blocks in program. Can you tell me how many blocks involve in one FC? size of one FC?
8/29/2017 7:26 PM | |
Joined: 9/27/2006 Last visit: 4/27/2024 Posts: 12257 Rating: (2665) |
Hello jabbi; I do not understand what you mean by "how manyblocks involve in one FC: But the size of each available FC is found in the technical docs of the CPU: https://support.industry.siemens.com/cs/pd/19586?pdti=td&lc=en-FR See below. Hope this helps, Daniel Chartier |
8/30/2017 4:12 AM | |
Dear how can i increase this range?
