12/5/2017 3:24 PM | |
Joined: 7/29/2016 Last visit: 10/8/2022 Posts: 18 Rating:
Dear Experts can we use CP243-1 with S7 200 CPU 224XP ? If yes , Please suggest supporting manuals. Thanks.
12/5/2017 3:52 PM | |
Joined: 9/27/2006 Last visit: 7/30/2024 Posts: 12272 Rating:
Hello electroautomates; Theoretically the CP 243-1 is compatible with all S7_200 CPUs. If you provide us with the part numbers and firmware versions of the CPU and the CP we can provide more detailed info. Here you wiill find some technical documentation on the CP 243-1: https://support.industry.siemens.com/cs/ww/en/view/18974029 What do you want to connect to, using a CP 243-1? For example: https://support.industry.siemens.com/cs/fr/en/view/17369594 https://support.industry.siemens.com/cs/fr/en/view/19724696 https://support.industry.siemens.com/cs/fr/en/view/23581294 There are many FAQs and Application examples that can help you out if you search for them on the Product Support pages (use the Search Box at the top right of this page); or come back to us with more details on your project. Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 12/5/2017 3:55:36 PMLast edited by: Jen_Moderator at: 12/6/2017 9:20:27 AMInserted right links. |
12/6/2017 7:06 AM | |
Thanks dchartier for your prompt response The part number of CP 243-1 is (6GK7 243-1-1EX00-0XE0) and the part number for CPU 224XP is (6ES7 214-2AD23-0XB0) I want to use CP 243-1 to get data from CPU 224XP at OPC Server (KepServer) |
12/6/2017 2:36 PM | |
Hello electroautomates; It appears that the CP module is compatible with the CPU you have, and with Microwin v4 SP9. Here are some documents and links that can help you out: - From Kepware : https://www.kepware.com/en-us/products/kepserverex/drivers/siemens-tcp-ip-ethernet/ - From Siemens : https://support.industry.siemens.com/cs/fr/en/view/14943706 https://support.industry.siemens.com/cs/pe/es/view/15355168 Hope this helps, Daniel Chartier |
