5/1/2018 11:36 AM | |
Joined: 12/7/2011 Last visit: 6/21/2024 Posts: 384 Rating:
Hi to all, Im woking on two F/FH systems (CPU 412-5 H PN/DP 6ES7 5HK06-0AB0 V6.0), where were already exist a safe comunication between theese two PLC's. What i did, it's been just add another comunication task for exchange more variables, after i've downloaded the software and the connections again, i got a strange error. In the BMS, who send the information all seems to be ok no error code in the RET_VAL, and i can monitor the block as well. In the BCS instead, who receive the informations, i got a strange problem. In the RET_VAL i didn't got any error, but when i try to monitor the block i got this error: "You can only monitor IO that represent an address in CPU memory" Any suggest? Does anyone know how can i fix it? I'm either looking for some safe comunication manual, but without success. Thanks in advance Regards Duccio. AttachmentCommunication error.pdf (135 Downloads) |
5/2/2018 10:20 AM | |
Hi guys, I've uploaded another attachement, any suggest? Regards. Duccio AttachmentSafe comunication error.pdf (135 Downloads) |
