(3)| 1/13/2017 9:16 AM | |
Joined: 4/28/2015 Last visit: 4/24/2025 Posts: 3345 Rating:
The attached document shows an example how to print the left cap of the IOT2000 with a 3D printer. You cand find the 3D model here. ------------------------------------------------------------------------------------------------------ Update 07.04.2017: Here you can find a detailed .stp file of the left cap. ------------------------------------------------------------------------------------------------------ Best regards! AttachmentIOT_3D_Print_Left_Cap.pdf (1545 Downloads) |
Last edited by: bergmanu at: 4/7/2017 3:33:15 PMLast edited by: bergmanu at: 4/7/2017 3:33:57 PMadded link to detailed left cap Not working for IOT2050 support anymore from March 1st, 2024. |
| 4/7/2017 3:11 PM | |
Hi, sorry this is a mistake in the document. Thanks for the hint! This will be corrected immediately. For example there is FreeCAD to open .stp files and saving them as .stl files. Best regards! |
| 4/16/2017 12:15 PM | |
Posts: 37 Rating:
Hi, in the meanwhile I created my own 3D model of the left lid cover using OpenSCAD. You can find it here: SIMATIC IoT 2000 2020 2040 left lid cover parametric on Thingiverse It doesn't try to resemble the original lid cover, but it is optimized for 3D print and allows you to change some parameters. Best Regards, Michael |
| 5/16/2018 10:16 PM | |
Posts: 439 Rating:
Hello bergmanu, Yes please, it would be awesome. Sorry for the delay, I have too much to do and forgot to add post to my favorites. Have a good day! Hugo |
| 5/17/2018 8:38 AM | |
Look at your private messages. The file is too big for upload in the forum. Best regards! EDIT: I made it to upload it :) Attached you can find the IOT2040 case. AttachmentIOT2040_Case.zip (1137 Downloads) |
Last edited by: bergmanu at: 5/23/2018 9:50:38 AMuploaded file Not working for IOT2050 support anymore from March 1st, 2024. |
| 5/23/2018 9:51 AM | |
And here is the IOT2020 case AttachmentIOT2020_Case.zip (1175 Downloads) |
