7/11/2018 2:32 PM | |
Joined: 12/12/2016 Last visit: 4/8/2024 Posts: 640 Rating:
Hello, I haven't tried exporting a Makefile out of Eclipse yet, but I have a workaround if you want to create an eclipse project with CMake GUI. Let us know if this works well for SDK 2.2. Kind regards! Attachmentiot2000_cmake.zip (328 Downloads) |
7/13/2018 7:53 AM | |
Posts: 19 Rating:
Thanks Fe_lipe, would be great if you find out whats the Problem. I also tried a few things yesterday but not really found out whats the Problem Kind regards |
7/17/2018 5:58 PM | |
I tried modifying the toolchain file and added the sysroot directory (--sysroot=...) to CMAKE_C_FLAGS and CMAKE_CXX_FLAGS. This eliminated the errors of some libc libraries not being found. But the CMake output is still the same and its still not able to configure the OpenCV build environment. Have you tried using OpenCV as static libraries and utilizing them in your project? Or what exactly is your goal with OpenCV? Kind regards! |
7/19/2018 1:34 PM | |
Posts: 19 Rating:
Thanks Fe_lipe again! I added the following lines you suggested in the CMake toolchain file. Kind Regards Attachmentworkaround_cmake_eclipse_opencv.pdf (340 Downloads) |
2 thankful Users |
