8/6/2018 7:56 AM | |
Joined: 9/9/2015 Last visit: 10/10/2024 Posts: 728 Rating: (279) |
It is possible but you might need to customized some block icon. Here is a suggestion 1. Create new hierachy/folder for each replica. One hierarchy = one new picture, you name it. This picture should have the static background. 2. Define your model in IEA. Textual interconnection, block icon, symbol name. Your template should be configured with all parameters and signals that are unique in each replica. 3. Configure your hierachy in IEA. Each hierachy = different pictures. 4. Import your chart. Block icons should be auto generated in your static pictures. |
Please give me 5 stars Rating if my post is helpful for you. :) |
8/8/2018 1:25 AM | |
Dear Unity01,
By using IEA, you are able to change the chart name, chart and block comment, hierarchy location (which define block icon location). When you generate block icon, the very first time, you got to arrange the @ block icon by yourself. It will be placed up left again if you generate it again. If the block icon you wanted is not generated, this might be due to the block type is not exist in @pcs7typicalxxxx. Hope these are helpful for you. |
