9/15/2008 2:36 PM | |
Joined: 7/15/2008 Last visit: 1/23/2024 Posts: 382 Rating:
Hello a_amer If you are installing a new network with CAT 5 Cable you do not need to replase your CP Cards . I your Transceivers are falling, you can replace them with new 10Base-T Transievers that have RJ45 Port.(Centrecom or Cabletron Transceivers). Please see attached PDF. If you need moreassistance please feel fee to contact me Attachment0346_02.pdf (254 Downloads) |
9/15/2008 3:55 PM | ||||||||||
Posts: 487 Rating:
I do not see arequirement of a data concentrator forjustthreeS5 systems. WinCC allows upto 60 PLCconnections on Ethernet layer 4. It is still not clear what CP you have. But if you want to replace CP, I would use CP1430TCP. The table below shows the possiblity of connecting over ethernet layer 4 with WinCC.
http://www.matrikonopc.com/opc-drivers/284/base-driver-details.aspx |
