12/27/2017 5:35 AM | |
Posts: 7 Rating: (0) |
Hi, In WinCC V7.3 I have assigned menu using "picture tree manager". And same backup I am using in V7.4 +Sp1. Problem- I am not able to add a new menu using Picture tree manager. in V7.4 Sp1. But if I follow the same procedure in the old version it is successful. Kindly revert back if any solution. How to add new menu from "Picture tree manager" ------------------------------------------------------------------------------------------ |
Last edited by: CS Moderator at: 12/28/2017 11:25:59 AMNew subject after splitting |
1/5/2018 1:50 PM | |
Joined: 10/5/2016 Last visit: 12/13/2022 Posts: 82 Rating: (46) |
Hello, in this case i would recommend you to make a service request: https://support.industry.siemens.com/cs/ww/en/sc/2090 Or the help of wincc 7.4 should help you as well. Kind regards |
11/4/2018 7:06 AM | |
Posts: 4 Rating: (0) |
hi.... i am also not able to insert new node in picture tree using wincc 7.4 sp1...i have installed this software in windows 10...please help me...its urgent |
