3/13/2019 3:52 PM | |
Joined: 11/8/2005 Last visit: 6/5/2024 Posts: 335 Rating:
Hi, I want to know is it possible to use CP340 in PCS7 V9.0? Thanks |
3/13/2019 4:32 PM | |
Joined: 5/3/2017 Last visit: 5/21/2024 Posts: 673 Rating:
Hi SM, you can find all released Hardware from PCS 7 in the manual SIMATIC Process Control System PCS 7 Released modules (V9.0). If you find the CP340 you can use it otherwise it is not tested an released from Siemens. So, if it's not released and you used the CP340 and run into problems, Siemens will not able to help you. With regards |
