7/26/2019 4:12 AM | |
Joined: 9/9/2015 Last visit: 9/30/2024 Posts: 727 Rating: (278) |
Based on my limited knowledge, I understand that in PCS 7 Alarm_8p message system, when Sig_X = 1, the alarm come and 0 = gone/went out. For your case, I assume you connect the signals from hardware configuration->DI channel driver blocks-> Digital monitoring OCM blocks. What I do normally is inverting the signal from DI channel driver block to Digital Monitoring OCM blocks to have 0 equal to normal, 1 equal to alarm. Then, by changing the Text_0 and Text_1, I displayed the message status correctly. Text_0 to Normal, Text_1 to Alarm. Does anyone have a better solution? |
Please give me 5 stars Rating if my post is helpful for you. :) |
7/26/2019 12:19 PM | |
What u mean is , you do not want to see Going message in your AlarmOneLine and Incoming Alarm List, am I right? Then you can configure it in alarm configuration dialog of the @alarmoneline.pdl or @alarmnew.pdl page. Untick the went out. |
7/28/2019 9:52 AM | |
Hello RouzbehAslani, I do not know how to put an OS text reference (Text 0 and Text 1) into Alarm_8P message. And for those messages, one line of message display only "come" or "gone" signal only. for your case, you would like to show text 0 and text 1 in the event list. I have a suggestion. MonDiS has 2 external message input, Sig4 and Sig5. You may make use of the input to display Text 0 and Text 1 message. Not sure whether it is helpful for you or not. You may check the pictures I attached for you. AttachmentProcessMessage.zip (251 Downloads) |
7/28/2019 3:50 PM | |
Joined: 11/30/2016 Last visit: 4/10/2022 Posts: 12 Rating: (3) |
Thanks JazTai,it was really useful but in this case when i turn on simulation mode of a MonDis (from faceplate) and try to change the state of signal. the desired event is not generated according to simulated value. (because the messages are created from output of Pcs7Din and it is not according to simulation value of MonDis. |
7/29/2019 4:19 AM | |
Great that you have the function you want. Anyone have better solutions? |
