10/7/2019 7:59 AM | |
Joined: 12/31/2018 Last visit: 3/10/2024 Posts: 96 Rating: (3) |
Hello Everyone, Did Anyone tried M-Bus Integration with Desigo CC through ''WTV-531- Level Converter"? Please Share your views or methods for M-Bus integration. Thank you. AttachmentWTV531-GA5060_en.pdf (384 Downloads) |
10/7/2019 1:59 PM | |
Joined: 11/8/2017 Last visit: 4/29/2024 Posts: 315 Rating: (170) |
Hi, I see your issue now. There's no mention of the 485 connection that would go to your PX controller. I've attached the WZC-P60 data sheet as an example - the M-Bus and 485 connections are shown for this type of device. As mentioned above, I'm not familiar with the WTV-531 device, but it looks likely that this is the wrong device, and not what you need for integrating M-Bus into a PX. Regards, AttachmentWZC-P60_M-Bus-signal-converter_CE1N5382en.pdf (392 Downloads) |
10/7/2019 2:40 PM | |
Hi, Yes, it's confusing and not entirely clear how this is meant to be a replacement for the older devices. I would contact your local Siemens people for more advice. Although not available from Siemens, the 250 device is still around. Have a look here. Regards, |
