6/11/2020 9:34 AM | |
Joined: 4/28/2017 Last visit: 3/14/2024 Posts: 149 Rating:
Hello Natthavat, Check this article from Siemens support team, How do you program the overlapping of tags with the keyword "AT" in the STEP 7 (TIA Portal)? Also, This is having information about Memory slicing, |
Last edited by: The Helping Hand at: 06/12/2020 08:34:49Optimized links. Note: If this post did really help you, you may use the "Rate" button to express your support, Thank you. |
6/11/2020 10:21 AM | |
Posts: 6 Rating:
I'm able to select AT overlay in S7-1200 Porject when disable "Opimized block access" But in this poject I can not. |
6/11/2020 10:22 AM | |
Posts: 6 Rating:
6/11/2020 10:25 AM | |
Posts: 6 Rating:
6/11/2020 10:38 AM | |
Posts: 6 Rating:
Yes. It's work with an SCL code block. I might need to concider to coding in SCL block. Thanks. |
