8/21/2020 7:40 AM | |
Joined: 4/28/2015 Last visit: 9/9/2024 Posts: 3345 Rating: (379)
Hi, did you already check /var/log/node-red.log? You can set logging of node-red to trace mode editing /home/<user>/.node-red/settings.js (https://nodered.org/docs/user-guide/runtime/logging) EDIT: In regards of your other post: You said that also network is down and after a while it comes back. Did you wait some more minutes and check if node-red also comes back after some time? Best regards! |
Last edited by: bergmanu at: 08/21/2020 07:42:45Not working for IOT2050 support anymore from March 1st, 2024. |
8/26/2020 8:06 AM | |
Hm hard to say.. Can you maybe share your flow? I can have a look at it and check if it crashes for me as well. Also if it crashed on an IOT2050.. And maybe I can find a reason. Maybe you can also open an issue at the node-red forum in parallel. I guess there are some more guys who could point you in the right direction where this crash comes from. Best regards! |
