8/25/2020 6:33 AM | |
Joined: 2/4/2020 Last visit: 3/26/2024 Posts: 41 Rating: (2) |
Tried, but it didn't work |
8/28/2020 7:41 AM | |
Joined: 2/14/2012 Last visit: 11/12/2024 Posts: 91 Rating: (21) |
Hi shippai See my comments in this thread. The difference to the PLT navigate command is that it will not close the current session and open the chosen working overlay. However it does log into the working layer and you can access objects by the LoadObjectByType command for example or you can change values of attribute. That does work, but it's all through scripting. That makes it a bit confusing. It would be helpful to know what exactly your use case is. Cheers Th. |
