1/15/2019 4:10 PM | |
Posts: 4 Rating:
hi, I want to install java in my siemens iot2000, but i don't know that it is necessary. Where i can download a java? Someone explain me who need to execute my .jar inside to SIEMENS IOT2000? Now, only install image. I has a WINSCC to send recods directly inside SIEMENS, but where i put , for example , jre-8u191-linux-i586.tar? thi record is correct to run java? Thanks, SERGI. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 1/16/2019 11:30:15 AMNew subject after splitting |
1/15/2019 4:26 PM | |
Joined: 12/12/2016 Last visit: 4/8/2024 Posts: 640 Rating:
Hello, I have tried building and installing the A better option would be to build an image containing java. Check out this post for a few hints on how to do so. Kind regards! |
1/17/2019 12:25 PM | |
Joined: 4/28/2015 Last visit: 6/3/2024 Posts: 3345 Rating:
Hi, you can add jre8u171 to your IOT2000 easily. Download jre-8u171-linux-i586.tar.gz from here. You have to register to Oracle for free in order to download this old version. The latest version does not work on the IOT2000. Then copy the tar.gz file to your IOT and execute the following commands:
Thats all Best regards! |
2 thankful Users |
3/5/2020 10:57 AM | |
Hello, Are you sure you downloaded the correct file? The file can be copied to /home/root it is just important the the contents end up in /usr/java after untar. Kind regards! |
9/17/2020 8:17 PM | |
Posts: 2 Rating:
hola tiene que colocarlo en el directorio usr / java intente trabajar con esta herramienta de windows, WINSCP, Permite el manejo de carpetas SSH, EL USUARIO mediante ES root y contraseña es root. o por consola MASILLA, SSH Java para plataformas Linux Cambie al directorio en el que desee efectuar la instalación. Escriba: cd nombre_ruta_acceso_directorio Por ejemplo, para instalar el software en el directorio / usr / java, escriba: cd / usr / java / Mueva el archivo binario de almacenamiento .tar.gz al directorio actual. Desempaquete el tarball e instale Java tar zxvf jdk-8u5-linux-i586.tar.gz tar zxvf jdk-8u261-linux-i586.tar.gz tar zxvf jdk-8u261-linux-arm32-vfp-hflt.tar.gz Los archivos Java se instalan en un directorio denominado jre1.8.0_05 en el directorio actual. En este ejemplo, se ha instalado en el directorio /usr/java/jre1.8.0_05. Suprima el archivo .tar.gz si desea ahorrar espacio en la disco. 2.- JAVA HOME 1 Edita el archivo PATH del sistema /etc/profile y agrega las siguientes variables de sistema a tu PATH. Usa gedit, nano o cualquier otro editor de texto, como root, y abre /etc/profile Teclea, copia o pega: sudo gedit /etc/profile o Teclea, copia o pega: sudo nano /etc/profile 2 Deslízate hacia abajo con las teclas hasta el final del archivo y agrega las siguientes líneas debajo de tu archivo /etc/profile en Linux, vamos a cambiar los números de versión del Java viejo al nuevo, cambiarás estos números de versiones en el siguiente archivo PATH /etc/profile: Modifica el archivo /etc/profile: export JAVA_HOME=/usr/java/jdk1.8.0_05 export PATH=$JAVA_HOME/bin:$PATH export JAVA_HOME=/usr/java/jdk1.8.0_261 export PATH=$JAVA_HOME/bin:$PATH Guarda el archivo y salte probar ejecutando :java –version si queremos instalar descargando sudo apt install openjdk-8-jdk |
Last edited by: davichog at: 09/17/2020 20:19:26Last edited by: davichog at: 09/17/2020 20:21:54 |
