11/11/2020 3:01 AM | |
Joined: 11/10/2020 Last visit: 11/14/2022 Posts: 6 Rating: (0) |
Hi All ! Wincc telecontrol 7.4, wincc 7.5, TIA v16 they are connected via standard DNP3 (module CP1243-1). I want to ask if they can transmit data to each other. I have tried but with no success, I don't know if wincc telecontrol 7.4 is compatible with wincc 7.5. Thank you very much ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/11/2020 10:36:48New subject after splitting |
11/11/2020 10:55 AM | |
Joined: 10/10/2014 Last visit: 5/17/2024 Posts: 1725 Rating: (209) |
Hi Vu_Truong, I found only TelControl V3.1 Up3 but no WinCC telecontrol V7.4 See Compatibility Tool for Automation and Drive Technology https://support.industry.siemens.com/cs/ww/en/view/64847781 Best regards schufri |
11/11/2020 8:28 PM | |
Joined: 1/17/2020 Last visit: 5/24/2024 Posts: 46 Rating: (6) |
Hi, WinCC/Telecontrol V7.4 Upd2 is compatible with WinCC 7.5 SP1, take a look to attached image. I saw the compatibility list using compatibility tool Compatibility Tool for Automation and Drive Technology Rate the post PLS! |
