12/7/2016 10:43 AM | |
Joined: 12/9/2010 Last visit: 10/8/2022 Posts: 623 Rating: (76) |
Hello BM, If it's ethernet cable, then you just need to worry about screen resolution. If TV screen resolution is same as HMI screen resolution then no problem. Otherwise you have prepare separate projects with different screen resolution. Also you should post this problem in Visualization conference. |
Last edited by: Sachinpatke at: 12/7/2016 10:46:04 AMIf you like the comment, rate it (right top) or thank it (left bottom). |
