2/14/2017 12:17 PM | |
Joined: 11/28/2016 Last visit: 7/4/2022 Posts: 13 Rating:
What do I should write in parameter LADDR of AG_RECV block? Where can I find module start address? |
2/17/2017 1:23 PM | |
Joined: 8/3/2009 Last visit: 3/14/2025 Posts: 14990 Rating:
Hello mister93 you have to use other blocks as for the internal Ethernet Ports of you PLC. You will find them in the block Library at Simatic Net CP Blocks. you will also find further information in this FAQ: https://support.industry.siemens.com/cs/ww/en/view/18610307 Bye Murof |
