Industry Online Support
11/28/2011 10:24 AM | |
Posts: 3037 Rating: (192)
Hello, The KTP 1000 basic has no possibilities to archive messages or tags. You can also take a look in this FAQ. You can see all function of all panels. What are the functional differences between the different SIMATIC panels? You can see in the following FAQ an example of KTP1000 with all functions. Demo projects for HMI Panels at WinCC (TIA Portal) for Basic Panels, Comfort Panels and WinCC Runtime Advanced (TIA Portal) Tweety |
11/29/2011 3:06 PM | |
Hello, You can use a tag with data type Word for the trigger tag of messages. You can find more information in the help of WinCC V11 under "Visualize processes > Working with alarms > Working with alarms > Configuring Alarms >Alarms in the HMI tags Editor > Configuring discrete alarms". Tips for WinCC Advanced: Alarm configuration Tweety |
12/1/2011 1:25 PM | |
Joined: 11/25/2011 Last visit: 12/6/2022 Posts: 3 Rating: (0) |
this worked out ok thanks for the support! |
