7/11/2013 8:38 AM | |
Joined: 1/21/2013 Last visit: 9/4/2024 Posts: 4620 Rating: (707) |
Hello Amit_86, What frequency do you work? |
7/11/2013 10:41 AM | |
Joined: 4/20/2007 Last visit: 9/12/2024 Posts: 724 Rating: (42) |
Hi, I think you should be looking for a high speed counter, not a DI module. The CPU I use (31xC) only takes 24 VDC I believe. Same goes for the FM 350 module. Perhaps there is other series that do take different voltages. You can also put in a pulse to analoge converter. I did a quick and dirty google search and came up with a few, this isone. I have used similar devices to convert pulses from a gas counter to a 4..20mA signal, works fine.
