10/18/2017 1:16 PM | |
Joined: 8/3/2009 Last visit: 3/21/2025 Posts: 15056 Rating:
Hello gesteen you also can use the OPC Server on the S71500 PLC if the PLC has a Firmware Version V2.X. Here is a little example:
Or you can use another Software for example Industrial Databridge: I hope it helps. Bye Murof |
