Industry Online Support
12/21/2011 5:08 PM | |
Posts: 47 Rating:
My HW is 2 xCPU315-2DP (2AH14) +SW_Redundancy+ 3 xET200M 2x153-2BA02-0XB0+active backplane. How to detect insert/delete signal module from ET200M? |
12/21/2011 6:56 PM | |
Joined: 9/27/2006 Last visit: 9/24/2023 Posts: 12153 Rating:
Hello Alex; Since your Profibus masters are S7-300you do not support CIR (Configursation in Runtime, which requires OB83 [not supported by S7-300 CPUs], see the link to the CIR manual in the following post by H-H): /tf/WW/en/Posts/50986 This means that if you remove a module (or insert one), even with the active backplane you will have an BF LED on your CPUandET 200M, andand a OB86/OB121 call in the CPU. Hope this helps, Daniel Chartier |
12/27/2011 1:02 PM | |
Posts: 47 Rating:
However, step7 Hardware diagnostic indicate themodule available/module noin slot |
12/27/2011 4:28 PM | |
Posts: 47 Rating:
SFC51 , SSL_ID=W#16#B4 Give me link to help please! |
