10/3/2010 11:05 AM | |
Joined: 1/28/2009 Last visit: 9/10/2024 Posts: 6849 Rating: (1365) |
Hi dear H_H Thanks for your informative post.Please check the attachment in which 2 DO are connected via 2 diodes to a relay.Is it possible to implement such configuration with SIEMENS modules or external diodes should be bought? Best regards hdhosseini Splitted from Isolated Channel for DO. Attachmentred_out.zip (122 Downloads) |
10/3/2010 12:49 PM | |
Joined: 7/2/2008 Last visit: 8/26/2024 Posts: 928 Rating: (308)
Hello hdhosseini, Siemens has some digital output modules with internal diodes for parallel operation. The attached PDF has been extracted from S7-400H manual. You can also find which modules have internal diodes when you look at the detailed specification in S7-300 module data. Best regards. H-H AttachmentRED-DQ.pdf (164 Downloads) |
