11/7/2018 7:15 AM | |
Joined: 5/6/2010 Last visit: 12/5/2024 Posts: 1992 Rating: (279) |
Hello Kach_man, Iwould suggest you the follow from Phoenix Contact: for trancduce the TC: and for duplication of the signals: Signal duplicator - MINI MCR-2-UNI-UI-2UI-PT - 2905028 If you use the voltage output of the trancducer then can you also wire 2 inputs parallel. Hope this is helpful. regards |
