11/12/2014 8:08 PM | |
Posts: 5225 Rating:
Hi there. I think you are looking in the wrong place for the mode adjustment. Attached are x2 pictures. 1) TIA V13 has intensive help to explain how that type card can be used 2) The parameter that I think you wish to adjust. I may be wrong.. I invite you to explain again to correct my understanding. It will be most helpful if you showd us which parameter you can not adjust. Regards. w AttachmentVisual Clue_ET200 Pulse .zip (156 Downloads) |
11/13/2014 9:30 AM | |
Joined: 12/29/2011 Last visit: 1/24/2022 Posts: 4 Rating:
HereI attached some screenshot with the configuration in TIA portal and Step 7 5.5. I opened a support request with siemens, if they solve my problem I will post the solution.
AttachmentConfig TIA vs Step 7.pdf (182 Downloads) |
