10/14/2022 7:43 AM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello igoienet Which Version do you use exactly in TIA Portal ? There is an Upd5 for V17 available. https://support.industry.siemens.com/cs/ww/en/view/109784441 also you should have installed the WinCC Panel images already on your system (DVD3) then you should also install the latest Update package for the Panel images from: https://support.industry.siemens.com/cs/de/en/view/109746530 Then you should have a Image V17.0.0.5 on your Comfort Panel. Bye Murof |
