Industry Online Support
9/9/2010 12:50 PM | |
Posts: 2964 Rating:
Hello... This alarm is on which axis? Spindle / linear / Rotary axis? >Could you try to increase the contour tolerance 36400 and check..... >Check the power module of the particular drive....interchange if you have. >Check the power module by keeping the multimeter in the DIODE mode. attaching the document of the same . Hope this will be useful.... check it out,,, Regards, Ekalavya AttachmentChecking procedure for FDD-MSD Module.pdf (476 Downloads) |
9/10/2010 6:10 AM | |
Posts: 159 Rating:
Try reseating the drive control card within the LT module. Is problem on accel/deceleration? |
