4/7/2016 1:51 PM | |
Joined: 7/9/2015 Last visit: 3/20/2025 Posts: 4202 Rating:
Hi, I think you should delete data on this mmc or use a newer one. You can delete Data only with USB Prommer or a Field PG but never with a normal MMC Device of your PC. Please look here: https://support.industry.siemens.com/cs/de/en/view/13992345 Normally the PLC has MPI adress 2 after reset to factory settings. I think the PLC reads another configuration from the card. You can try other PG/PC Interface settings like automatic to get connection. This is also interesting for you: https://support.industry.siemens.com/cs/de/en/view/29801950 Regards, Towome |
