3/31/2014 4:24 PM | |
Joined: 4/24/2006 Last visit: 3/21/2025 Posts: 8904 Rating:
Hello zaid_b, Perhaps this thread might help: /tf/WW/en/Posts/9962 Best regards, Wizard |
3/28/2018 3:03 PM | |
Joined: 3/2/2018 Last visit: 11/4/2018 Posts: 1 Rating:
Hello everybody If anyone else found the solution for question mentioned above can explain the please? Thank you |
3/28/2018 3:12 PM | |
Joined: 4/28/2015 Last visit: 2/24/2025 Posts: 10832 Rating:
Hello, pls describe what HWs you want interconnect, pls in detail. |
With best regards... |
3/28/2018 4:14 PM | |
Joined: 5/8/2016 Last visit: 2/15/2024 Posts: 167 Rating:
hey you can use s7 connection between the 3 cpu , by using connect (unknown device) putting the target CPU ip address when you configure the connection . and use put/get instruction in the program . if you still have a problem setup tia portal and try to it by tia portal ,look at this pdf am using here s71200 to connect to s7 300 its the same method may that help regards ahmed hamad Attachments7_conn.pdf (156 Downloads) |
Last edited by: elctro hamad at: 3/28/2018 4:18:30 PMLast edited by: elctro hamad at: 3/28/2018 4:19:32 PMA lot of potential remains |
