11/20/2014 1:52 PM | |
Posts: 366 Rating: (30) |
Hi, and this temperature is not really increasing? Make a compare measuring with a thermometer! nice regards
11/24/2014 10:28 PM | |
Joined: 7/2/2008 Last visit: 4/5/2024 Posts: 928 Rating: (305) |
Hello Arif, Why do you connect one end to ground? I mean it's not how it is in the manual. Do you connect the RTD with 2,3 or 4 wires? Can you measure the RTD resistance at module side (i.e. RTD+Cable) when the difference is 5 and also when it's 10 or 12? Please use anyPT-100 tableand check whether the module is reading a correct value according to measured resistance and the relevant temperature value in the table. Best regards, H-H
