6/7/2011 3:16 PM | |
Joined: 1/28/2009 Last visit: 3/8/2025 Posts: 6860 Rating:
In Rslinx you can find the AB softwares with the online available tags.You can define each AB CPUs as a provider (server) in OPC simply br right-click on it and define it as OPC server with specified name.In SIEMENS side , you should use SIMATIC NET -OPC SCOUT for gathering items from AB CPUs. You can use the defined items in WINCC. Please also check this topic: How to connect to WinCC OPC Server regards |
6/7/2011 4:16 PM | |
Check the following attachment as a series of snapshots to show you how can a AB controller can be defined as the OPC server. hope to be helpful regards AttachmentOPC_DEFINITION.zip (154 Downloads) |
