1/17/2018 1:56 AM | |
Posts: 5 Rating:
Hi! I can't find the 3SU1803-0AB10-4HB1 AS-Interface enclosure on the TIA-Portal V15. Is there a GSD file for that? Thanks for the help! |
1/17/2018 7:08 AM | |
Joined: 4/23/2010 Last visit: 11/23/2024 Posts: 8092 Rating:
Hello AutoGen_3202899 You need to install CP so as to install & configure ASi interface. HTH |
4/27/2018 11:23 AM | |
Joined: 8/3/2009 Last visit: 3/21/2025 Posts: 15056 Rating:
Hello which PLC do you use exacly?? perhaps the basic way of doing helps: https://www.youtube.com/watch?v=EQjGG_FybK4 Bye Murof |
Last edited by: Jen_Moderator at: 4/27/2018 12:36:04 PMInserted video. If this Information really helps, you could use the Rate function |
5/1/2018 5:15 PM | |
Joined: 2/12/2018 Last visit: 1/13/2021 Posts: 19 Rating:
Hi, any help for that would be greatly appreciated :) |
