11/30/2021 10:39 AM | |
Joined: 4/9/2021 Last visit: 10/25/2022 Posts: 23 Rating:
Hello wams23, In Analog Amplifier block you can't Scale your value from 0 to 700 but the solution is this : You need to Scale your analog value with mathematic Instruction block here is the Project Example. Check it please. If it was helpful, do not forget rating AttachmentAnalog Scaling Example.zip (154 Downloads) |
