12/29/2019 9:36 AM | |
Joined: 5/6/2010 Last visit: 4/24/2024 Posts: 1963 Rating: (272) |
Hello, the easiest way is you use transducer e.g. from Phoenix Contact. If I understand it right do you nee DI 200 mV = FLASE and 800 mV = TRUE For Analog IN you can use e.g. Signal conditioner - MACX MCR-UI-UI-NC - 2811446 For the digital out can you use a relay or a solid state relay, but you need the switching voltage. What for a signal do you need for your analog out? regards |
