5/9/2012 6:45 AM | |
Joined: 12/1/2009 Last visit: 5/2/2023 Posts: 669 Rating:
Dear Ganesan_K, where did you see 64 bit floating points in SIMATIC S7 ? Regards. |
Give us your feedback and show us your respect! |
5/9/2012 6:57 AM | |
Joined: 1/3/2006 Last visit: 4/21/2023 Posts: 726 Rating:
Hi Accumulator size in S7 CPU is 32 bits ! So can't accomodate more bits then that !
5/9/2012 7:42 AM | |
Joined: 3/21/2006 Last visit: 4/12/2023 Posts: 10221 Rating:
Hello, As that issue was discussed beforeUsing DOuble Float in STEP7 Best regards, Hristo Mihalev
5/9/2012 7:53 AM | |
Posts: 8946 Rating:
It is possible using some special funktions blocks. Please have a look at OSCAT library! Some mor helpfull links: http://support.automation.siemens.com/WW/view/en/56600676 http://support.automation.siemens.com/WW/view/en/56098697 |
5/9/2012 9:18 AM | |
Dear manmeet , what I read on the available library is that it just convert 64 bit into 32 bit. If this it whatyou understand under processing 64 bit, yes it's possible. What I understand under 64 bit processing is handling the 64 bit without anylosses (add, multiply, divide, compare.....). By nature the CPU does not support this functionality. But it should be possible tomake this via additional blocks on software base. Regards. |
