4/5/2013 7:01 AM | |
Joined: 3/21/2006 Last visit: 7/12/2023 Posts: 10221 Rating:
Hello, DId you have another card to test it? That card, does it "belong" to the CPU or you took it from another project? About manual, take a look in
Best regards, Hristo Mihalev
4/5/2013 1:22 PM | |
Posts: 5 Rating:
The memory is came with CPU when I order it. I don't know if it has program inside. I check with an new in a box and empty memory card and the results are the same. So, if I use a manual for CPU315 is ok?
4/5/2013 2:18 PM | |
Posts: 5 Rating:
Thank you ... |
