3/16/2009 8:21 PM | |||||
Joined: 12/22/2006 Last visit: 1/25/2022 Posts: 1742 Rating: (308) |
Hello, There is an entry here: http://support.automation.siemens.com/WW/view/en/29289048 The cable you mention is a Pre-assembled cables for connection between ET200 module and MTA
It is suited for the MTA 6ES7650-1AD10-2xx0 Discrete Output 16-Channel 24 VDC The pinout is in chapter 13.6 of this manual http://support.automation.siemens.com/WW/view/en/22091986 |
Best regards |
3/25/2009 5:34 PM | |
Posts: 18 Rating: (1) |
Thank you for the reply.. Nonetheless, what I want is different. Anyhow, I got it from Siemens hotline directly. I attached the file for your reference. Thanks again Attachment6es7922_3Bxx0_0AT0.pdf (201 Downloads) |
11/29/2013 12:38 AM | |
Posts: 1 Rating: (0) |
Also thanks for this pin assignment Regards Bruce |
