4/11/2023 7:16 AM | |
Posts: 1 Rating: (0) |
Hi support team, i had encounter similar fault at my 6RA8085 DCM. F067 activated after 6 sec turn on. Check r13, show 22'C. Room temperature 20'C and fan working well. after change new drive n down load parameter, same fault occur. may i know where the set point of F067 n at which temperature should trip F067? Which parameter that i can change temperature setting? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/11/2023 11:29:27New subject after splitting |
