5/23/2012 7:56 AM | |
Posts: 2964 Rating:
Hello... Normal RS232 cable is sufficent. Have you tried checking with your other PC ? Ensure you have kept the same baudrate details properly. Check this Link of Docon WEB: https://www.automation.siemens.com/doconweb/content.asp?item=12210&cd=sinumerik_simodrive_04_2010_e&scope=all Regards, Prakash |
5/23/2012 8:08 AM | |
Posts: 38 Rating:
Please find the RS232 Connection details in the attached file........... If u want to take a data backup Like Machine data, Part program, Sub program etc... at the time U make sure on the PLC is not in transferring mode. If u want to take a PLC backup via Programming tool V3.1 at the time U switch on the PLC transferring mode.
AttachmentRS232 Pin details.pdf (373 Downloads) |
4/8/2016 9:40 AM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating:
New question published by hamid ghorbani is split to a separate thread with the subject 802C Handshaking, set Xon/Xoff but no data send to controller. Best regards |
