6/23/2013 10:58 AM | |
Posts: 664 Rating:
Hai Ekalavya, Thanks for the Support... Can you able to tell me how/what is the procedure to set these liscences.? How i make it work ?? Thanks&Regards, Raj |
6/23/2013 3:41 PM | |
Posts: 2964 Rating:
Hello, Have these License are purchased ??? These License need be purchased then only it is going to be worked / if it is not purchased it gives you the error message "Option activated with out License".If Option is purchased and you need to enable you need to go to Setup >Press the Etc key(>) after this go to Licenses
