12/26/2017 10:11 AM | |
Joined: 4/23/2010 Last visit: 12/31/2023 Posts: 8092 Rating: (877) |
Hello KuzemkoA, Please check 828D machine data spindle axis MD 32260 value, set it to 4000 RPM as per your requirement, retaining other parameter values as it is & check if you get the required speed. HTH. |
1/9/2018 1:15 PM | |
Posts: 8 Rating: (0) |
32260=4500. p1082[0]=8000. And I cant ger requried speed. Also I set maximum speed for my gear stage. |
1/10/2018 7:50 AM | |
Hello KuzemkoA, What are the values in P2000[0], P2001[0], r0313[0], r0070[0]? Have you carried out automatic calculation by setting P0340? (Ofcourse prior to commissioning with 828D system) |
1/10/2018 9:31 AM | |
P2000[0]=1150.0 P2001[0]=1000 r0311[0]=1150.0 r70=530.0. Automatic calculation P0340 not run. |
