12/23/2009 12:34 PM | |
Posts: 60 Rating:
Dear Pee Ell Sea adn Nulizhang, Thank you very much for your response to my post. As per your suggestion i did the following thisngs 1.Copied thementionedfiles from failed drive into working drive 2.Fixed the working hard drive in the machine 3.When bootingup, the machine goes to NC general reset mode 4.I have tried to load NC MD, PLC MD, CYCLE MD and PLC user prog (ANW_PROG) by using the procedure (Made by me from 840C doc on CD which is attached for your reference). 5. Till step 55 everying goes well. At step 56 theerror message "165033 - conversion has not been switched off" displayed in a pop up window. 6. At top of the screen error message "300009 - MSD drive not loaded". I am not able to proceed further and expecting your help... Thanks, Venki Attachment840C data loading procedure.pdf (877 Downloads) |
