6/21/2013 1:05 PM | |
Posts: 2964 Rating: (484)
Hello, When you clear NC ....yes ofcourse the data will go off and it will restore the factory setting... Does your 840D is with PCU 50 / MMC103 You can restore you backups if you have it. check this link for the :-Creating /restoring the NCPLC arechive backups /tf/WW/en/Posts/60254#top NC PLC clearing steps... /tf/WW/en/Posts/45967#top Check it out and revert back... Regards, Prakash |
6/21/2013 2:42 PM | |
Hello, Fine thanks for the update.....why do you get the error? check this FAQ for information. http://support.automation.siemens.com/WW/view/en/592955 Regards, Prakash |
6/22/2013 7:13 AM | |
Hello, Looks like your NC backups have problem....do you have any other NC backups with you. Try loading it and check. Regards, Prakash |
